THOUGHT that`d whet your appetites........Guiness Drink
Called to a hotel the other day - They`ve got individual 2KW heaters in each guest room, fed via a contactor in the adjoining dist cupboard / dry riser.
Behind reception, they`ve got 119 illuminated toggle switches in a grid. 1 switch per room.
should be straightforward this; each switch fires the associated contactor, operating the heating, yes?
NEARLY!
Ten rooms ( together) weren`t operating. The maintenance guy`d had a look in this panel, and found a relay which, when partially withdrawn, caused the rooms to work again........... ? :|
I get there - (no diagrams, info or contractor details) - and find 15 relays on a top hat rail, along the top of this board. Each relay is a 5V coil, 4 pole 2 way unit; with only one pole connected. The "faulty" relay is the only one energised; and the wiring is N/C.
Does anyone on here have the foggiest idea what these relays might be doing there? I can`t understand why we`ve got 5V relays firing banks of rooms (which are on different phases, mind you), configured to break the circuit when 5V is delivered to a relay. WHY, FCOL? What purpose do they serve? What is their mission? Who is their leader? Are they just trying to send me demented?????????
H E L P ! (please)
KME
NEARLY!
H E L P ! (please)
KME
