Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Trickle voltage at extractor fan
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Andy99" data-source="post: 528243" data-attributes="member: 35129"><p>Hi folks, thanks for feedback. Reading 17.5v at fan (switched) L & N terminals.</p><p>SL and PL clearly marked, so not reversed. Not 100% sure if fan wired in series or parallel (replacing old fan with new and existing wiring). Will a new light switch solve the problem?</p><p>Thanks</p></blockquote><p></p>
[QUOTE="Andy99, post: 528243, member: 35129"] Hi folks, thanks for feedback. Reading 17.5v at fan (switched) L & N terminals. SL and PL clearly marked, so not reversed. Not 100% sure if fan wired in series or parallel (replacing old fan with new and existing wiring). Will a new light switch solve the problem? Thanks [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
