Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Trying to find suitable LED dimmer switches
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ElectricAlex" data-source="post: 474507" data-attributes="member: 30888"><p>Ok so I am using this dimmer switch with the Philips bulbs as stated in the original post:</p><p></p><p><a href="http://amzn.eu/d/758F2Qx" target="_blank">http://amzn.eu/d/758F2Qx</a></p><p></p><p>I've installed it in three rooms (3 dimmer switches total). It was a straightforward A/B swap with the old switch. Back box did not need changing.</p><p></p><p>Installation was easy. Works great, could not be happier. Thanks for everybodies help.</p></blockquote><p></p>
[QUOTE="ElectricAlex, post: 474507, member: 30888"] Ok so I am using this dimmer switch with the Philips bulbs as stated in the original post: [URL="http://amzn.eu/d/758F2Qx"]http://amzn.eu/d/758F2Qx[/URL] I've installed it in three rooms (3 dimmer switches total). It was a straightforward A/B swap with the old switch. Back box did not need changing. Installation was easy. Works great, could not be happier. Thanks for everybodies help. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
