Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Trying to identify a very old household bulb?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Marvo" data-source="post: 559036" data-attributes="member: 20838"><p>I've never seen the round peg type so every day is a school day. I've only seen the oval peg which was an s14s for the twin single-contact caps or s14d for the single oval dual-contact cap in the middle of the fitting. The oval peg lamps are still available in LED variants like Osram LEDInestra but I doubt they'd be interchangeable with the round peg fitting you have which I'm guessing is Cromptons own version. </p><p>The only reasonable option is to replace the fitting with something more modern and more energy efficient that will last probably 6 months rather than the 60 years the old fitting probably worked for.</p></blockquote><p></p>
[QUOTE="Marvo, post: 559036, member: 20838"] I've never seen the round peg type so every day is a school day. I've only seen the oval peg which was an s14s for the twin single-contact caps or s14d for the single oval dual-contact cap in the middle of the fitting. The oval peg lamps are still available in LED variants like Osram LEDInestra but I doubt they'd be interchangeable with the round peg fitting you have which I'm guessing is Cromptons own version. The only reasonable option is to replace the fitting with something more modern and more energy efficient that will last probably 6 months rather than the 60 years the old fitting probably worked for. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
