Hi i am going to install a new air compressor. It suggests installing onto a 30 amp supply. I have a 30 amp supply.
The air compressor will be controlled by a float switch in a water tank which is about 60 meters away. The float switch is only rated at 10-15amp so my question is what can i use to connect the float switch to the compressor to turn it on and off?
Is there a contactor or a starter of some sort that i can wire in line for this?
The float switch is only a 2 wire switch so i think it used in line of the live wire. live goes in, through the float and back out to turn whatever on and off. Sorry if i have missed anything out.
