sirsparkabit
- Mar 19, 2008
- 437
- 14
Hi guys a little senario i very rarely come across , i will be very glad if you think my solution is o.k. here we go----------
Extended two circuits which are on main board (no rcd so am changing this to 17th ed as you would.
Small board with main switch for first shower 6mm cable 30 amp rewirable, so will incorperate this shower into new board,no problem with exceding rating of main switch in new board.
Second Shower in small Conactum unit 63A main switch 40A breaker(no rcd) so should i leave as is and mark down on comments on existing installation on my cert no rcd reqires upgrading,or change for shower unit with Rcd and charge accordingly.
I dont want two showers fed from same board if i can help it:O
Suppply fuse is 60/80A dont know which yet. :_|
