I have had electrical underfloor heating for 4 years. 5 mats each with an Aube TH132 control unit and Aube PB130 base. The largest controls a mat of approx 21 sq metres and it doesn't work.
When the control unit switches on after a minute or so the LCD display fades and goes blank, resets and the floor will not get warm. I swapped the control unit to another mat and it works fine, but a new unit on the original base/mat has the same problem - blank screen, no heat and then the display reads as if it has been turned on after initial installation.
All other mats are OK, so I think maybe I need a new base unit? Also the resistive load on the base should not exceed 3450Watts at 230V (max 15A) and I wonder if that may be the reason it has failed. I have read that a contactor and a snubber may be needed, but have no idea whether my system has them or where they might be sited. I am tempted to buy another base unit and wire it in, but wonder if this is a DIY proposition?
Sorry for so many questions but any advice would be helpful, thanks Mick
