Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Using 220V Ac appliance on 240V AC grid
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Doc Hudson" data-source="post: 478849" data-attributes="member: 1607"><p>What country are you referring to? The UK voltage tolerances that appliances have to work to are: 'Nominal 230v' +10% / -6%. So the permitted voltage range is 216.2v to 253v. How stable is your declared 240v supply. What min/max tolerance are allowed for variation? All appliances should work to a satisfactory level between the max min, of the country they are intended for. It is not a case that it would suddenly fail if the supply voltage wasn't exactly the same every day. That total 16% variation allows for over 36v difference that the same appliance must carry on working OK. How accurate is your assumed 20v difference? </p><p></p><p>Doc H. </p></blockquote><p></p>
[QUOTE="Doc Hudson, post: 478849, member: 1607"] What country are you referring to? The UK voltage tolerances that appliances have to work to are: 'Nominal 230v' +10% / -6%. So the permitted voltage range is 216.2v to 253v. How stable is your declared 240v supply. What min/max tolerance are allowed for variation? All appliances should work to a satisfactory level between the max min, of the country they are intended for. It is not a case that it would suddenly fail if the supply voltage wasn't exactly the same every day. That total 16% variation allows for over 36v difference that the same appliance must carry on working OK. How accurate is your assumed 20v difference? Doc H. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
