Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Wago wiring correctly
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="OnOff" data-source="post: 559564" data-attributes="member: 16173"><p>I'll happily admit when WAGOs first came out I had a selection box of the various types and kept putting off using them. Finishing off a rewire the last thing to do was replace a charred, brittle batten lamp holder in the loft and test. </p><p></p><p>I removed the old batten holder and realised I had an angled instead of straight replacement. To temporarily make safe, instead of putting a traditional connector block on I thought I'd try one of those "new ones"...and wrapped it in tape for good measure.</p><p></p><p>[ATTACH=full]17276[/ATTACH]</p><p></p><p>I didn't go back to the house immediately and totally forgot about the loft / batten holder.</p><p></p><p>I started testing...the IR results threw me for a bit and was wondering where I'd accidentally screwed / nailed through a cable. </p><p></p><p>It was then I realised the value of dead testing!</p></blockquote><p></p>
[QUOTE="OnOff, post: 559564, member: 16173"] I'll happily admit when WAGOs first came out I had a selection box of the various types and kept putting off using them. Finishing off a rewire the last thing to do was replace a charred, brittle batten lamp holder in the loft and test. I removed the old batten holder and realised I had an angled instead of straight replacement. To temporarily make safe, instead of putting a traditional connector block on I thought I'd try one of those "new ones"...and wrapped it in tape for good measure. [ATTACH type="full"]17276[/ATTACH] I didn't go back to the house immediately and totally forgot about the loft / batten holder. I started testing...the IR results threw me for a bit and was wondering where I'd accidentally screwed / nailed through a cable. It was then I realised the value of dead testing! [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
