Thanks Noz, I think i get the jist+1(2)
Oh, blinking heck,,, that's made it complicated,,, I'd say a code 2!
Ah, now i understand!! Thanks again....I think Andy was thinking that instead of coding it that you could just stick it in as a spur from a ring MCB.... Easy fix
if it only feeds 1 DS then its no different from a spur from a 32A MCB.Thanks Noz, I think i get the jist---------- Post Auto-Merged at 22:45 ---------- Previous post was made at 22:40 ----------
Out of interest Andy, would you code it 1 if it was only supplying 1 socket?
not again.....Im not so sure about that,if its on a 32 on its own then I would argue not, its a defined radial circuit with an overrated protective device............
Unfortunately not, it's for a letting agent who wants it coded then quoted. if i get the report spot on it could mean a fair bit of work....Can't you just change with a spare 20a you may have in the van and put it on the price of the PIR your doing.
