Hi
In my (new) consumer unit, there are 3V across the Neutral bar and the earth bar, when the mains is off. There is also 53V across the mains switch from L to N when it's off and 44V between the line supply and line out. Is this normal when the mains switch is off? Isn't N and Earth connected together at some point therefore should be 0 volts difference?
Could this explain why my LED bulbs never switch off but only go dim when switched off via a wall switch?
See pics for actual readings - does anyone know what the readings should be in a good installation?
Thanks in advance...
