Normal
The problem with LED's is the wattage in a lot of cases doesn't reflect on how bright the lamp will beThe best indication of how bright the lamp will be is the Lumens / watt output although some lamps only have an overall Lumen outputI would suggest you need to be looking for around 90 - 100 Lumens / watt
