jibspark
Electrician
- Oct 16, 2008
- 425
- 0
get a call, shower switch keeps sparking and blowing the fuse!
ive been round and 10mm line in the back of the shower isolator has blown a little insulation away (i think it was just under a bit of pressure on the side of the box), the cable itself looks ok, a bit of charing on the line and others but wipes off. there isnt enough cable to cut it back and re-terminate.
would you cut it back and put a join in the back of the box? not a massive amount of room.
or would you re-insulate the cable using heatshrink?
i couldnt fix it there and then as it needed a new switch.
