description: CPU
product: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz
vendor: Intel Corp.
physical id: 400
bus info: cpu@0
slot: Microprocessor
capacity: 1600MHz
width: 64 bits
clock: 1066MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx constant_tsc arch_perfmon pebs bts nopl aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm lahf_lm dtherm tpr_shadow cpufreq
configuration: cores=2 enabledcores=2 threads=2
*-cache:0
description: L1 cache
physical id: 700
capacity: 32KiB
capabilities: internal write-back data
*-cache:1
description: L2 cache
physical id: 701
capacity: 2MiB
capabilities: internal varies unified
*-memory
description: System Memory
physical id: 1000
slot: System board or motherboard
*-bank:0
description: DIMM DDR Synchronous 533 MHz (1.9 ns)
product: KC6844-ELG37
vendor: Kingston
physical id: 0
serial: A81C90A7
slot: DIMM_1
width: 64 bits
clock: 533MHz (1.9ns)
*-bank:1
product: VS1GB667D2
vendor: 7F7F9E0000000000
physical id: 1
serial: 00000000
slot: DIMM_3
width: 64 bits
*-bank:2
vendor: Kingston
physical id: 2
serial: AB1C7AA7
slot: DIMM_2
width: 64 bits
*-bank:3
product: VS1GB667D2
physical id: 3
serial: 00000000
slot: DIMM_4
width: 64 bits
*-pci
description: Host bridge
product: 82P965/G965 Memory Controller Hub
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 02
width: 32 bits
clock: 33MHz
*-pci:0
description: PCI bridge
product: 82P965/G965 PCI Express Root Port
physical id: 1
bus info: pci@0000:00:01.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:40 ioport:d000(size=4096) memory:dfd00000-dfefffff ioport:c0000000(size=268435456)
*-display:0
description: VGA compatible controller
product: RV516 [Radeon X1300/X1550 Series]
vendor: Hynix Semiconductor (Hyundai Electronics)
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
configuration: driver=radeon latency=0
resources: irq:16 memory:c0000000-cfffffff memory:dfde0000-dfdeffff ioport:dc00(size=256) memory:dfe00000-dfe1ffff
*-display:1 UNCLAIMED
description: Display controller
product: RV516 [Radeon X1300 Pro] (Secondary)
physical id: 0.1
bus info: pci@0000:01:00.1
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress bus_master cap_list
configuration: latency=0
resources: memory:dfdf0000-dfdfffff
*-network
description: Ethernet interface
product: 82566DC Gigabit Network Connection
physical id: 19
bus info: pci@0000:00:19.0
logical name: eth0
version: 02
serial: 00:19:d1:26:14:2a
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=1.5.1-k duplex=full firmware=1.1-0 ip=192.168.1.3 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:44 memory:dffe0000-dfffffff memory:dffdb000-dffdbfff ioport:ecc0(size=32)
*-usb:0
description: USB controller
product: 82801H (ICH8 Family) USB UHCI Controller #4
physical id: 1a
bus info: pci@0000:00:1a.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: uhci bus_master
configuration: driver=uhci_hcd latency=0
resources: irq:16 ioport:ff20(size=32)
*-usb:1
product: 82801H (ICH8 Family) USB UHCI Controller #5
physical id: 1a.1
bus info: pci@0000:00:1a.1
version: 02
width: 32 bits
clock: 33MHz
resources: irq:17 ioport:ff00(size=32)
*-usb:2
product: 82801H (ICH8 Family) USB2 EHCI Controller #2
physical id: 1a.7
bus info: pci@0000:00:1a.7
version: 02
width: 32 bits
clock: 33MHz
capabilities: pm debug ehci bus_master cap_list
configuration: driver=ehci_hcd latency=0
resources: irq:22 memory:dffdac00-dffdafff
*-multimedia
description: Audio device
product: 82801H (ICH8 Family) HD Audio Controller
physical id: 1b
bus info: pci@0000:00:1b.0
version: 02
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:45 memory:dffdc000-dffdffff
*-pci:1
product: 82801H (ICH8 Family) PCI Express Port 1
physical id: 1c
bus info: pci@0000:00:1c.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
resources: irq:41 ioport:3000(size=4096) memory:dfc00000-dfcfffff ioport:d0400000(size=2097152)
*-pci:2
product: 82801H (ICH8 Family) PCI Express Port 5
physical id: 1c.4
bus info: pci@0000:00:1c.4
version: 02
width: 32 bits
clock: 33MHz
resources: irq:42 ioport:1000(size=4096) memory:d0000000-d01fffff ioport:d0200000(size=2097152)
*-usb:3
product: 82801H (ICH8 Family) USB UHCI Controller #1
physical id: 1d
bus info: pci@0000:00:1d.0
version: 02
width: 32 bits
clock: 33MHz
resources: irq:23 ioport:ff80(size=32)
*-usb:4
product: 82801H (ICH8 Family) USB UHCI Controller #2
physical id: 1d.1
bus info: pci@0000:00:1d.1
version: 02
width: 32 bits
clock: 33MHz
resources: irq:17 ioport:ff60(size=32)
*-usb:5
product: 82801H (ICH8 Family) USB UHCI Controller #3
physical id: 1d.2
bus info: pci@0000:00:1d.2
version: 02
width: 32 bits
clock: 33MHz
resources: irq:18 ioport:ff40(size=32)
*-usb:6
product: 82801H (ICH8 Family) USB2 EHCI Controller #1
physical id: 1d.7
bus info: pci@0000:00:1d.7
version: 02
width: 32 bits
clock: 33MHz
resources: irq:23 memory:ff980800-ff980bff
*-pci:3
product: 82801 PCI Bridge
physical id: 1e
bus info: pci@0000:00:1e.0
version: f2
width: 32 bits
clock: 33MHz
capabilities: pci subtractive_decode bus_master cap_list
*-isa
description: ISA bridge
product: 82801HH (ICH8DH) LPC Interface Controller
physical id: 1f
bus info: pci@0000:00:1f.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: isa bus_master cap_list
*-storage
description: RAID bus controller
product: 82801 SATA Controller [RAID mode]
physical id: 1f.2
bus info: pci@0000:00:1f.2
logical name: scsi2
logical name: scsi4
logical name: scsi5
version: 02
width: 32 bits
clock: 66MHz
capabilities: storage msi pm bus_master cap_list emulated
configuration: driver=ahci latency=0
resources: irq:43 ioport:fe00(size=8) ioport:fe10(size=4) ioport:fe20(size=8) ioport:fe30(size=4) ioport:fec0(size=32) memory:ff970000-ff9707ff
*-cdrom
description: DVD writer
physical id: 0
bus info: scsi@2:0.0.0
logical name: /dev/cdrom
logical name: /dev/cdrw
logical name: /dev/dvd
logical name: /dev/dvdrw
logical name: /dev/sr0
capabilities: audio cd-r cd-rw dvd dvd-r
configuration: status=nodisc
*-disk:0
description: ATA Disk
product: SAMSUNG HD502HJ
physical id: 1
bus info: scsi@4:0.0.0
logical name: /dev/sda
version: 1AJ1
serial: S20BJ9AZ604699
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 signature=0009c45c
*-volume:0 UNCLAIMED
description: EXT4 volume
vendor: Linux
physical id: 1
bus info: scsi@4:0.0.0,1
version: 1.0
serial: d83fbbe4-e5a6-448b-90d6-2058c0e251fd
capacity: 243MiB
capabilities: primary bootable journaled extended_attributes huge_files dir_nlink recover extents ext4 ext2 initialized
configuration: created=2012-09-26 21:34:34 filesystem=ext4 lastmountpoint=/boot modified=2012-10-30 23:34:04 mounted=2012-10-30 23:34:04 state=clean
*-volume:1 UNCLAIMED
description: Extended partition
physical id: 2
bus info: scsi@4:0.0.0,2
capacity: 454GiB
capabilities: primary extended partitioned partitioned:extended
*-logicalvolume:0 UNCLAIMED
description: Linux filesystem partition
physical id: 5
capacity: 450GiB
*-logicalvolume:1 UNCLAIMED
description: Linux swap / Solaris partition
physical id: 6
capacity: 3811MiB
capabilities: nofs
*-volume:2 UNCLAIMED
vendor: Linux
physical id: 3
bus info: scsi@4:0.0.0,3
version: 1.0
serial: 48339857-530a-4b96-bce1-08c558158da5
capacity: 11GiB
capabilities: primary journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
configuration: created=2012-09-26 21:34:35 filesystem=ext4 lastmountpoint=/ modified=2012-09-26 22:08:18 mounted=2012-10-30 23:34:03 state=clean
*-disk:1
physical id: 0.0.0
bus info: scsi@5:0.0.0
logical name: /dev/sdb
version: 1AJ1
serial: S20BJ9AZ604703
vendor: Linux
physical id: 1
bus info: scsi@5:0.0.0,1
version: 1.0
capacity: 243MiB
physical id: 2
bus info: scsi@5:0.0.0,2
capacity: 454GiB
physical id: 5
capacity: 450GiB
physical id: 6
capacity: 3811MiB
capabilities: nofs
vendor: Linux
physical id: 3
bus info: scsi@5:0.0.0,3
version: 1.0
capacity: 11GiB
*-serial UNCLAIMED
description: SMBus
product: 82801H (ICH8 Family) SMBus Controller
physical id: 1f.3
bus info: pci@0000:00:1f.3
version: 02
width: 32 bits
clock: 33MHz
resources: memory:dffdab00-dffdabff ioport:ece0(size=32)
*-scsi:0
physical id: 1
bus info: usb@2:2
logical name: scsi6
capabilities: emulated scsi-host
configuration: driver=usb-storage
*-disk:0
description: SCSI Disk
product: USB HS-CF Card
vendor: TEAC
physical id: 0.0.0
bus info: scsi@6:0.0.0
logical name: /dev/sdc
version: 4.00
capabilities: removable
*-medium
physical id: 0
*-disk:1
product: USB HS-xD/SM
vendor: TEAC
physical id: 0.0.1
bus info: scsi@6:0.0.1
logical name: /dev/sdd
version: 4.00
*-medium
physical id: 0
*-disk:2
product: USB HS-MS Card
vendor: TEAC
physical id: 0.0.2
bus info: scsi@6:0.0.2
logical name: /dev/sde
version: 4.00
serial: 3
*-medium
physical id: 0
*-disk:3
product: USB HS-SD Card
vendor: TEAC
physical id: 0.0.3
bus info: scsi@6:0.0.3
logical name: /dev/sdf
version: 4.00
*-medium
physical id: 0
*-scsi:1
physical id: 2
bus info: usb@2:6
logical name: scsi7
*-disk
product: Photosmart B110
vendor: HP
physical id: 0.0.0
bus info: scsi@7:0.0.0
logical name: /dev/sdg
version: 1.00
*-medium
physical id: 0
