Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Wiring a replacement PIR lamp with permanent live.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ProDave" data-source="post: 561740" data-attributes="member: 6969"><p>So now you have created a problem, that you don't know which pair is the live and neutral feed, and which pair is the probable switch drop.</p><p></p><p>We try to tell people to take pictures and identify each core somehow BEFORE disconnecting anything but it falls on deaf ears.</p><p></p><p>Most PIR lamps these days come with a flying lead, so your first job will be to fix a waterproof junction box to the wall to terminate those cables, and then when you have identified which is which you can terminate them and then connect your new light.</p></blockquote><p></p>
[QUOTE="ProDave, post: 561740, member: 6969"] So now you have created a problem, that you don't know which pair is the live and neutral feed, and which pair is the probable switch drop. We try to tell people to take pictures and identify each core somehow BEFORE disconnecting anything but it falls on deaf ears. Most PIR lamps these days come with a flying lead, so your first job will be to fix a waterproof junction box to the wall to terminate those cables, and then when you have identified which is which you can terminate them and then connect your new light. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
