- Jul 8, 2010
- 373
- 0
Ok guys need some opinions please, priced a re wire on a 3 story building, children's nursery . And have today been told they got someone half my price so thought I would see what you guys think.
They have had a new fuseboard recently 12 way.
I know pricing depends on a lot more detail than I can give but on what to I can tell you I would like your opinions.
they require the following.
30 x 2 gang switched sockets
25 x 1 gang 1 way light switches
4 x 2 gang 2 way light switches
29 x 6" light pendants
2 x cooker switchs and connection plates
5 x switched fuse spurs
2 x 5ft strip lights
approximate cable sizes as not at home now is,
400/500 metres of 2.5mm twin amd earth
400 metres of 1.5mm twin and earth
30 metres of 10mm twin and earth.
30 metres of 3 core and earth
all cables to be chased into walls and all backboxes to be replaced as most got damaged lugs on. Chasing for cable runs to be plastered over.
Works need to be started on a Friday evening after 6pm and work weekend and be in fit state to leave for children on a monday. Then the same again the following week.
there is floorboards from 1st floor but I woud habe to move all furniture and carpets. Ground floor is concrete floor to basement area.
Now if I say quote was in the region of £3500 would you say that was cheap or expensive? I will tell you exact price later when home.
all bonding to gas,water done and meter tails were upgraded when customer had previous spark install consumer unit.
I appreciate your honest opinions
