jurassic spark
Would a CU with Wylex push button mcb's get a satisfactory EICR?
There is a front end RCD at the installation. I've also noticed that you can still buy these mcb's, thought that was a bit strange.
Or. 1361s. Then jam a 1362. 5A plug fuse in and wonder why the two halves of the holder don't close ( or better still a 13 A fuse )why is it strange? you can still fit 3036 fuses if you want....
You cannot purchase new the push button type (BS3871 type B). The toggle type are still readily available.
nothing wrong with those in their own right.Would a CU with Wylex push button mcb's get a satisfactory EICR?
