Car radiator fan vent.
am-il-hi
Apr 26, 2024
Dorset
I recently acquired a 16" car radiator fan that I intend to mount on some perspex for use as an extractor fan on my brew hut window.
The fan states it is 12v 120 watt so I understand that makes it 10 amp.
I have a unit that converts mains supply to 12v 15 amps from some spotlights I used to have.
Will the fan burn out or am I all good?
No the fan will just draw the 10 amps it needs and the power supply should hapilly run at 2/3 of it's magimum power.
BUT check first this is a DC power supply. If it was just for spotlights it could just be a simple transformer with an ac output.
Thank you for the speedy response.
That was my hunch but I just got those last minute doubts. Also I just did a double check and it is DC output.
Thank you ProDave.
You might find the power supply can't handle the startup (inrush) current, they can draw quite a bit when they first kick in.
