S Sonoff_HelpMe New member Joined Mar 29, 2024 Messages 1 Reaction score 0 Location Wales, UK Mar 29, 2024 #1
Murdoch MEMBER Supporting Member Joined Aug 5, 2014 Messages 8,737 Reaction score 1,312 Location Woking Mar 29, 2024 #2 Looks to me as if you don't have a neutral at the switch so no it won't work. If you connect the neutral to the earth you'll trip the RCD
SPECIAL LOCATION Trailer Boy - Electrician. Supporting Member Joined Mar 28, 2008 Messages 14,320 Reaction score 968 Mar 29, 2024 #3 All you have is a permanent live, a switched live and an earth... No neutral!
ProDave Twatt ™ Supporting Member Joined Nov 28, 2009 Messages 14,680 Reaction score 832 Mar 29, 2024 #4 Choose a different smart switch that does not need a neutral. Some work by charging a battery from L / SL when the load is turned off.
Andy™ ©Resident Geordie™ Supporting Member Joined Jan 1, 2009 Messages 30,550 Reaction score 1,245 Location S. Tyneside Mar 29, 2024 #5 the switch isn't suitable for the wiring you have. you need to either replace the wiring or the switch
kerching ©Kleenex™ Supporting Member Joined Oct 22, 2010 Messages 14,521 Reaction score 1,086 Location Home for the terminally bewildered, one step ahead Mar 29, 2024 #6 To answer your questions in order NO YES….not actually blow it up but it won’t enhance it
Badger Gold Member Supporting Member Joined Feb 24, 2008 Messages 6,152 Reaction score 104 Location Staffordshire Mar 30, 2024 #7 Or get a 3 core and earth down to the switch from light fitting thereby giving neutral at switch
M michael8554 Gold Member Supporting Member Joined Dec 23, 2021 Messages 234 Reaction score 62 Mar 30, 2024 #8 Shouldn't the SonOff be installed in the ceiling behind the rose, where L, N and E are available ?
