mainline
Active member
- Joined
- Feb 9, 2022
- Messages
- 33
- Reaction score
- 26
That would only be true when using DP Rcbosat least with an RCBO board, and fault will only take out the affected circuit and not half the circuits
I have split these posts (From "Need help, old fuseboard changed...........") so the debate can continue. They will only serve to confuse the OP
