Dear ElectriciansI have had an Electrician intall 6ml wiring to a new Range master Excel double oven cooker that is 11 KW.
I am not an electrician, but I am very concerned that it is insufficient and could overload, Any thoughts ?....or brief comments are very welcome.
Thanks for your time. bad day explode
Welcome to the forum northbynorthwest....
Why are you "very concerned"...
As you say yourself you are not an electrician I am intrigued as to where your worries arise from?
Is the electrician a "full time professional" or a mate from down the pub doing a favour?
If the electrician is a member of one of the approved contractor schemes do you have specific reasons to doubt his ability's, installation methods etc.. etc..
If you do, you could use the contractor body helpline / complaint procedure to have a second opinion.
But that said..
on the face of it with the limited information you have given
and without actually coming out to see the work face to face..
I would guess its probably OK!
Do you have access to any electrical books?
If not pop to a library and have a look at a copy of "On Site Guide"
The cover looks like this...
IEE On-site Guide; BS 7671 : 2008 IEE Wiring Regulations 17th Edition: Amazon.co.uk: The Institution of Engineering and Techn: Books
Turn to page 160..
last but one paragraph..
Talking about domestic cookers is suggests a 32Amp circuit (which is comfortable on 6.0mm cable) is usually appropriate for cookers up to 15kW rating!
unless you can elaborate a bit more onto specific worries and reasons I cannot comment further.
:C
:coffee
