17th edition questions
noel2507
Jan 2, 2010
17
hi i'm revising for my 17th edition and having problem with a couple of question. know the answer but don't understand how to get there. any help i would be greatful
i have supplied the question and the answer but i don't understand how to get this answer could you please explain.
20 The fault current due to an earth fault of negligible impedance in a 400 V, three phase, four wire circuit
having an earth loop impedance of 0.3 , is
a 1383A
b 767A
c 124.5 A
d 72A.
Answer b 411.4.5
37 A circuit is protected by a 10 A BS 3036 semi-enclosed (rewireable) fuse. The minimum permissible
current rating (Iz) of a conductor protected by this fuse would be
a 7.25A
b 10A
c 13.8A
d 20A.
Answer c appx5 5.1.1
Look them up in the big red book, as far as the first one goes its a bit of a trick question because a 400V 3 wire system is still only 230V to earth! therefore the fault current is worked out by ohms law: I=V/R which is 230/0.3 which is 766.67A Prospective Short Circuit current is usually double this figure on a 3 phase system.
Don't know the second without looking it up.
i've been in the red book now for a few days really sick of the sight of this book now. it was a straight forward answer just me looking to far into things. if you get time the second question would be a big help. thanks
