17th edition test questions
noel2507
Jan 2, 2010
17
hi i'm revising for my 17th edition and having problem with a couple of question. know the answer but don't understand how to get there. any help i would be greatful
i have supplied the question and the answer but i don't understand how to get this answer could you please explain.
20 The fault current due to an earth fault of negligible impedance in a 400 V, three phase, four wire circuit
having an earth loop impedance of 0.3 , is
a 1383A
b 767A
c 124.5 A
d 72A.
Answer b 411.4.5
37 A circuit is protected by a 10 A BS 3036 semi-enclosed (rewireable) fuse. The minimum permissible
current rating (Iz) of a conductor protected by this fuse would be
a 7.25A
b 10A
c 13.8A
d 20A.
Answer c appx5 5.1.1
First one.
I=V/R
I=230/0.3= 766.6A
Second One.
Rating factor for a 3036 is 0.725
Rated current of protective device is 10A
10A/0.725=13.79
Not 100% on the first one, as i dont know if there asking for the measured value before it's doubled for 3phase. However 415/0.3=1383A
Dont forget its an earth fault therefore 230V - earth.......
Read it wrong, I presumed it was asking for the PFC on a 3phase system with a Ze of 0.3 :p
