I concurNice and neat that,, well done!Only thing I'd say is that for a large board like that is that you should consider using cable markers to identify the circuits
its actually a reg, dunno the number, but all conductors must be clearly identified,Nice and neat that,, well done!Only thing I'd say is that for a large board like that is that you should consider using cable markers to identify the circuits
Now that is picky, Spinny!! You'll confuse the guy.Very neat looking.Will each cable stretch to anywhere on the board, if for instance someone decided to have a shuffle round?
means you having to trace the cable, splitting cable ties etc,yes it has a isolator and i did not provide the board or mcbs!!!! also the top left is for lighting witch was not connected when i took pic?!!!1 all cables are numbered just abouve in the trunking. so i know were it all goes. as for moving equiptment all machines and run from board.
will do next time!!!means you having to trace the cable, splitting cable ties etc,sorry,
should be marked adjacent to the termination.
but, not bad at all for a 1st go,
as opposed to you being DIY.?will do next time!!!if u looked at it would u think it was done profesionaly ?
