Ucatchmydrift
Hi, have any of you knowledgeable chaps/chapes'es came accross an immersion heater element that is 11" (14" would also fit i think), is suitable for hard water areas, has a 2.25" bsp thread, and is 2kw, for a reasonable price (i call under £50 reasonable!)?
(i cant find one!)
(btw my inverter is 3kw)
As this is literally the last thing i need to switch over to my semi- off grid setup.
My immersion tank is 110ltrs and has two elements. I have found the top one on boost for 1 hour (3kw) is enough for a deep bath, so 2kw presumably should take about 1/3 extra time to heat up, which is fine as can be on a timer. Also, i will be using it for a shower mostly, (one of those tap push on shower jobbies) so, even less time id have thought to heat up enough water for a shower.
I could use two 1kw elements in series at a guess, but that comes out at £80+, which seems alot as a 3kw is about £20, presumably as they make so many of them.
Unless anyone knows of a way to reduce the power from a 3kw to a 2kw for a reasonable price? (im doubting this)
(i cant find one!)
