Guys, wondering if you can help me? Having had a quick read through I think I am in the right place!
We are having to service an unit and need to get readings. Our electrician is in hospital and we merely need a few readings using a clamp meter. I have worked along side this guy for years and told the boss I can get the readings (more fool me).
Anyway I have got all the voltage reading, current reading when the motor first starts (its a delta motor) and current readings once the machine is running under normal conditions.
However it goes into other more indepth running tests, thats the bit I normally do. Making sure the mechanical side is sound. But at each stage it just says amperage reading? The sparky has only put in 1 reading? How can this be when it is 3 phase? Is it an 'average' of the 3? Just puzzled as to how I can get only 1 amp reading!
Incidently the machine was serviced only 5 weeks ago but its our policy that it is checked again before it leaves the workshops/stores. Its amazing how much the readings can change. But so can the mechanical side due to temperature etc..
Thanks in advance guys. By the way quite an impressive site by the way! Loads of info
