sparky marky
- Nov 29, 2010
- 6
- 0
Hi all, I am currently installing a 3 phase supply to a new building. The supply is taken from an adjacent building where I have tail blocked the 3 phases and neutral coming in after meter and run a 25mm 4 core swa via a 63A rotary isolator (run is 28m). Supply is TNCS
The new building requires 3 phase downstairs for the garage/workshop and I have run a 63A supply off one phase to supply a 17th edition consumer unit to supply the flat up stairs. The customer is to be living upstairs and use the workshop downstairs for himself requiring various 3 phase supplies (16A/32A), a ring main and lighting circuit.
My first question is should I supply RCD protection for the workshop to comply with regulations? If so how is this best achieved on the 3 phase board?
My second question is regarding the earthing required.. I have installed an earth pin at the moment connected to the 3 phase board, should I rely on this for both the 3 phase board and flat consumer unit? or use the armoured sheathing to supply earth to the 3 phase board and use the pin for the flat's consumer unit?
Any advice will be much appreciated
Mark
Mark
