3 phase socket tester
harryspark
May 2, 2010
25
as part of my job i make up 16,32,63,125a sockets, just to make sure i want to make a socket tester to completely rule out fault, i am going to buy a 32a end, wire it onto 3 ph cable and use a grip gland into an adaptor box, and get a few 220vac leds to indicate continuity, my only problem is i need an in and an out of the connector to the led, and by the way the box will only be powered off a 13a plug with step up plugs, would you put any mcb or rcd connection on it?
