i am doing my 2391 practicle shortley and never done 3 phase testing before. can any one tell me the write way of testing 3 phase from start to finish.ie l1 to l2 l1 to l3 and so on just to make sure i have got it write.cheers men !!!!
you also need to check phase sequence (612.12), not just rotationWith you tester you put the l1 lead on l1 l2 on l2 and l3 on l3 if it wired corrcetly it wil be correct on display. I have a di-log 9073 for phase testing which goes in right sequence if I remember correctly. Best bet is to read instructions for tester. I don't think I have helped much here.
As per Tuesday`s job (and Weds, Thu & prob. Fri.......)The main problem with 3 phase is to get a good balance, so each phase in an ideal world will draw the same amps.
