3 Phase
GS
Apr 5, 2011
If someone has three single phase supplies to a property is it an issue to convert them to 3 phase?
Is this building converted from three separate properties? Or are all three single phases in one area?
The problem is that a three phase supply is installed from the available three phases, if a property was converted you may have two single phases from the same phase and the third from another, so it would not be a 3ph supply at all. You would have to apply for a supply upgrade to ensure a true three phase supply. You can not do a diy 3ph from three single phases.
Just strip the ends back...
bang em all in a Henley block...
Twist a bit of tape around the joint..
Best if you got Self Amalgamating.. (looks nicer!! :innocent )
230v+230v+230v = 690v..
you'll have the best part of 700volts then!!!!
:Blushing :p :popcorn:CGuinness
Do you understand the concept of 3-phase power generation ?
e.g.
How the Individual phases are 120degrees lagging or leading the other two associated phases?
So as manator says if you dont have 3 individual phases coming in..
2 of one + 1 of another or 3 of one and non of another...
Well..
what do you think?
Answers on a postcard to..
WHERES-THE-STUDENT-AND-LEARNING-ZONE-GONE,
I-CANT-FIND-IT.
PO BOX 3-PHASE
:| :coat
Welcome to the forum GS. Is this a hypothetical question or is there some genuine requirement?
