green-hornet
Distinguished Member
- Feb 25, 2009
- 3,741
- 0
I have been asked to look at a foreigner job, wiring an air compressor.
The factory I use to do some work for when I was a sole trader has just acquired a second hand 3ph air compressor, when I went to look at it the connections had been cut at source, there is only two connections, one is the feed to permo run the compressor, the other is the valve stop, or auto stop. I assume it works by user on/off (at workstation), then the compressor auto stops when up to the set pressure, then auto starts when below another set pressure.
Now here is my problem the control was left in the building, and is now gone with the rest of the building, its old but works fine, I doubt the old controller would be up to standards anyway. I would like the controls to be to current regs, and would appreciate any help or links to the type of controller I would need to fit, I am unsure about the amps it runs at, never thought to check but would assume not a great deal.
