Luke Moreland
Hello,
I have 8mm microbore to all rads (please keep reading), 4 rads up, 4 rads down.
I been living here 6 months and have always had a problem with a rad downstairs, it doesn't turn on. The previous owners had a cabinet there so may well have had the radiator permanently off.
I've done some cowboy work:
Other notes:
Should I consider running some cleaner through the system, is that wise with microbore? I don't want to dislodge some radiator sludge and cause a blockage elsewhere.
Any help is greatly appreciated.
Thanks,
Luke the Cowboy Plumber
- Balanced rads
- Turned all rads off but the problem one, inlet valve gets warm (not hot)
- Drained system & replaced rad (type11) with new one (type22) of same size and valves
- Refilled system and bled boiler and rads
Other notes:
- When refilling the heating system the new rad had a lovely jet of water from the bleed valve, suggesting the inlet valve allows a good amount of water in?
Thanks,
