I have Word invoices saved in a folder , They are nearly all titled " Inv. 1022 Clients name " . (Well obviously the numbers tend to differ :C )
They are in a strange order , numerically .... how could I click to say " Sort yourselves out into numerical order " ?
You have to remember the file names will be treated as text and sorted alpha numerically.. NOT as numbers.
So for example.. if you were back at 3 digit numbers and didn't add a preceding zero, (or space), in the file name the alphabetical orders will look wrong numerically.
Say you have four invoices:- 345, 567, 2345 & 4567 and just named them with a preceding 'INV' with no spaces or zeros..
the alphabetical order would be:- "INV2345, INV345, INV4567, INV567"
Which looks numerically wrong.. but is correct alphanumerically.
Or if you had a put a Zero before the 345, and a Space before 567... That will also look wrong as space comes before zero in the computers alpha sort..
so you would get:- INV 567, INV0345, INV2345, INV4567
which is getting better but the space -vs- zero will still mess up your listing..
AND... if you've gone and stuck a double space before some of the digits.. it can end up looking totally random!
If you have used a consistent name structure with the same number of digits for every job, then it will be just select sort on the file name in your file manager program..
Otherwise you may be a bit screwed!
:C
