the engineers code is NOT the same code you use to set/unset the alarm,thanks mate i know the code thank you have looked every where on the net for it
hi mate can you tell me what i have to do please cant see it on the manual
Steptoes pants maybe an easier option msl1:hi mate can you tell me what i have to do please cant see it on the manual
might need some industrial grade detergent though, :Blushing :|I am sure Mr Ninth will be along shortly with further advice on how to do it ut the kettle on :coffee :maria: .
Last one not needed but have only just spotted it
I would like to point out that "instructions" you gave a link to is for the "Abacus User Guide" which is of little use in this case.I gave you a link to the instructions & you say you have the engineers code. I suggest if you cant do it now you call an alarm engineer in your area.
If you dont know the engineers code you are most likely stuffed. How many codes do you have ?thanks how do i change to eng code A so i can then get into volume to lower it thanks
it says you can change in eng code from A B C D how do i get into change what i wont thanks
I am well aware of what it is, I was trying to help. I already asked a couple of questions which you have ignored, you were then given a link to the engineers manual. If you can not understand a manual for the piece of equipment you are asking about, you have little chance of being able to achieve your goal.thats a good answer mate lol remember me not to have you install an alarm lol lol its a burglar alarm
