templeofseven
So, I'm not an electrician and have been pondering this for some time, unable to find the answer.
From physics I learnt there are 3 current types,direct, alternating and static. However I'm somewhat confused with home wiring and AC.
I remember being taught that DC flows in one direction, conventionally from the positive terminal to the negative and that AC flow both ways at a particular frequency usually 50 or 60 cycles per second.
I've recently been installing new breakers into my consumer unit along with an RCD as it didn't have one.
My question is, why is only the line or live isolated with a breaker and all the neutrals common.
Surely if this is true AC then current should flow equally between the line and neutrals back and forth all the way back to the power station isolated along the way by step down transformers.
From discussions with electricians at work they believe current only flows on the line in a sinusoidal wave and not back and forth between the live and neutral. And that the neutral is bonded to earth at the customer side of the last transformer on route to your home.
In my mind this is just a variable voltage on the line with a voltage of zero to 240. In effect a varying DC voltage.
Please help
Please help
