Bsmiffffy
Hi I currently have a 100w solar panel that feeds into a pwm controller then into 2 12v 110Ah batteries connected in parallel.
This feeds into a caravan 12v system and works fine but I now need to add a 90w fridge to the system. It will run on gas during the winter and 12v during the summer.
I am replacing the 100w panel with a 400w panel and replacing the controller with an MPPT controller feeding into the same 12v batteries.
The caravan live feed comes from battery 2 and the negative from battery 1 so one 220Ah 12v battery.
My question is how do I stop the fridge from draining both batteries. I need to charge both from the solar but I only want the fridge to use one of the 2 batteries and leave the other for lights etc.
Thank you in anticipation.
