Mike Smith01
- Dec 5, 2024
- 2
- 0
Our stairs has a light at the bottom of them and a light at the top. The two lights are not independent of each other but there is an upstairs switch and one downstairs. So the lights can be turned on or off from either switch. I've recently found there is a current going through the earth of this group of lighting. I've checked the lights and the switches are wired correctly, they seem fine but I'm no electrician, I just have basic knowledge.
I've changed the switches for new ones but the current is still passing through the earth. The only thing I haven't tried yet is changing the bulbs or light fittings, but as I said, the wiring for them looks correct.
Anything else I could check myself before I have to get an electrician in?
