Air operated switch
That was with next day delivery and vat,,, but apparently I can't get next day delivery in North Wales,,, WTF!!!
I have also ordered the DP switch just in case the pump needs both flow switches bypassed
fitted this to a few different makes and only ever needed one reed switch bypasses
also with latching you need to press the button again to get it to turn off - if you use momentary, it switches off as normal
but i dont use latching switch. i use momentary with a positive head pump. wire the switch in parallel to the reed sensor in the pump
once it starts, it stays on. once shower is turned off and water stops flowing, the pump shuts down
Now there's an idea,,, ah well too late now as I've ordered the latching switch,, but next time;)
---------- Post Auto-Merged at 21:29 ---------- Previous post was made at 21:25 ----------
Cheers Andy,,
So you use CPC for this kind of thing then??
not something many sparks would use so wholesalers dont keep the stuff. ive had many blank looks at wholesalers when asking for various stuff.
for certain things, ive got more stock than the local wholesalers. and as for the air button.... im sure i have an air bellow, switch & tubing at my unit
