Ambiguous Questions?
`pache - I wouldn`t worry, as long as t`other one is current - Expect you use more skyhooks than underwater PME`s anyway??? :p
I'm on skyhooks plus, can't justify the extra expense of the skyhooks HD for dubious extra quality.
Quick question - how many skyhooks HD would I need to store my long weight? It really is getting on the girlfriends nerve laying around the spare room.
The assumption is inferred. ;)
As it should be, under these conditions mate.
However, a slight inclination of the cranium
is as adequate as a spasmodic motion of the optic cover
to an equine quadruped with no visual capacity.
Inference of an assumption is probably going to be made illegal in the not-too-distant future...............
I'm on skyhooks plus, can't justify the extra expense of the skyhooks HD for dubious extra quality.Quick question - how many skyhooks HD would I need to store my long weight? It really is getting on the girlfriends nerve laying around the spare room.
DUBIOUS extra quality? you`re having a giraffe!!!!!!
As for your "long weight" (fnarr fnarr) - depends on the girth, and how accessible you`ll need it to be late.
I`d expect somewhere between 12 and 74 (x10 EXP 14)
Getting on the GF`s nerve? I`ve never heard it called THAT before...............
KME?
sky hooks and skirting board ladders hmm favourite past times Applaud Smiley
nice thread :^O
In furred? Killing animals for their fur is wrong - killing them for their tasty meat is all fine and dandy and we wouldn't want that nice pelt to go to waste.......
:^O
In furred? Killing animals for their fur is wrong - killing them for their tasty meat is all fine and dandy and we wouldn't want that nice pelt to go to waste....... :^O
Applaud SmileyApplaud SmileyApplaud SmileyApplaud Smiley
and I quote.....
582.34.7.1
The Yellow shall not be sleeved Black, unless the CSA of the line conductor is equal to the square root of the MCB breaking capacity.
The following exclusions apply to TT installations,
(i) SWA run overhead clipped with sky hooks need not be sleeved.
(ii) MICC run vertically up lift shafts shall only be sleeved Blue on a Wednesday.
(iii) RCDs rated 30ma or higher shall only be used where they are needed.
You must not forget special location section 798 restricted air space. Clause 798.2.5
798.2.5
Sky hooks should not be used higher than 1.5m in areas of restricted air space to prevent the effects of undue stress on the apparatus as a result of impacts from flying objects such as planes, helicopters, migrating birds and flying objects from solar systems yet to be confirmed or identified.
The exception to this rule is if the sky hook is fitted with a xenon beacon with a red lens and a flash rate of no more than 30 flashes per calendar month and a battery back up system with at least 100 years capacity as required by the regulations for doomsday and the apocalypse BS666.
Well nothing needs moderating here, I think? Please let me know if it goes off topic, I shall leave you to your 'discussions'! I am unclear if Admin has issued the medication or not, is the before, or the after effects?
Very true Ian!Applaud Smiley
But I had heard that section 798 was to be split into two sub-sections when the new amendments come out in Juy2010?
becomes
Section 815 Restricted air space crossing garden pools, water features and rockaries.
Section 816 Air space unrestricted line of sight, excluding dense cloud environments.
