Any Excel experts
Andy™
©Resident Geordie™
Jan 1, 2009
30,787
1,508
S. Tyneside
i have a long list of numbers in column B (all 5 digits), but i need to copy them to row A. but the problem is, i also need to change them from ##### to *#####* (to a barcode font). any ideas?
All numbers are consecutive
i have a long list of numbers in column B (all 5 digits), but i need to copy them to row A. but the problem is, i also need to change them from ##### to *#####* (to a barcode font). any ideas?All numbers are consecutive
If I get your drift, enter the first three numbers cell by cell in the series, then highlight those 3 by left clicking over the cells, you will see a tiny square in right or bottom most cell, move the cursor over and it will change to a +, drag alone the cells, down the rows you wish to number and it will populate in the sequence, you can do this with time, days, months too!!
Let me look at the barcode bit, or send me an example file and I'll have a go
already tried. that way works fine for gettin all the numbers there, but if i add the *, it repeats the numbers i have highlighted
basically, i need column A to be
*50101*
*50102*
*50103* etc.
Column B will be above without *
for the barcode, i simply change the font (i have a barcode font installed, but if i dont add the *, it cant be read by a barcode scanner)
Also look at the custom option in format cell just in case I misunderstood what your asking
already tried. that way works fine for gettin all the numbers there, but if i add the *, it repeats the numbers i have highlightedbasically, i need column A to be
*50101*
*50102*
*50103* etc.
OK excel thinks * is multiply so is a reserved character if you put '*50103* it tells excel to treat as text, I have to go and eat now but if still stuck pm me
Enter your numbers in column BA1 should be ="*"&text(b1,0)&"*"
Copy to other cells in column A
Alter your font in column A to your Barcode font
Hope that helps
Or the other way =CONCATENATE("*",B1,"*") ;)
What the flipping heck are guys talking about? :|
