3
300TDI
Guest
Ok
Been called to look at an installation - on the way home job
Customer has a three phase fuse board - been there years, but looks ok
About 6 months ago they had a new room built, and a new consumer unit was installed to supply this ( not by me )
The consumer unit is fed from the three phase board, and has a main rcd switch, mcbs feeding various circuits - shower, hand dryers, lights, and an rcbo feeding sockets ( a bit strange been as the main switch is a 30ma rcd aswell ? )
The problem is that when he switches off a floor standing fan ( at the socket ) the rcd main switch trips, but the socket is fed from the fuseboard, not the consumer unit.
Also when the sangamo timer switches the blow heating system on, that also trips the rcd, and the heating circuit is fed from the fuseboard aswell, not the consumer unit.
Looks like a bit of testing to do, but i cant understand why the rcd main switch is being tripped when the circuits causing this are fed from the main fuseboard, as the rcd seems to be tripping as if something is being sent down the tails to the rcd main switch on the supply side - not the outgoing side.
What do you make of this ??
