- Joined
- Nov 28, 2009
- Messages
- 14,674
- Reaction score
- 829
I have a Daewoo direct drive washing machine model DWD-G1441S
The drum bearings are on their last legs. Is replacement feasible or even possible?
I have taken the motor rotor off for a look. I can see the outer bearing and the drum shaft.
It looks like a bit of a major strip down to gain access to split the drum outer casing. Then what?
First thing would be to push the shaft through and withdraw the drum How do I do that? just hit the shaft with a hammer?
Then if I manage that how do I get the bearings out? I assume there will be 2. How tight will they be? can I drive them out with a hammer and a bar? I can't see as I can apply heat as the drum outer casing is plastic.
Any thoughts as to whether this is possible if somewhat difficult, or not?
