electrics_new
hi
I am newly qualified and seek advice on the following:
I have arrived at a job and the previously electrical has left 2 sets of armored cables short (both 3 core 4mm wire).
One armored cable one circuit for outside low voltage lights into a 3AMP fuse - let's call this cable A.
The other end going into a consumer unit in the garage - which suppliers flood light (400watt), fluorescent light (40 watt) a radial (16AMP) socket that doesn't do much hardly ever used - let's call this cable B.
I am thinking the following;
Due to the cables being short terming, i am thinking of doing the following:
Cable A - terminate into a box - earth the armored sheath - connect to 1.5 twin and earth and terminate into the DB on a 6AMP MCB.
Cable B - terminate into a box - earth the armored sheath - connect to 2.5 twin and earth and terminate into the DB on a 16 AMP MCB.
Am I doing the right thing here..............
