assessment garage install singles or t+e
nothing wrong with T&E, i.e the conduit is additional protection.
just dont try and get 2x 2.5 & 1.5 T&E into the same bit of 20mm conduit
sunny rhyl, thanks very much assessment is a week tomorrow though, are you working on RAF valley?
there will only be one 2.5 in the one to the socket below the cu then 1mm to light and out of light to switch so only a max of two 1mm's from where the T will be, its better practiceto use singles i thought but im a tight arse..
If the joists are visible clip the T/E & only put conduit drops to switches/sockets, use a female adaptor at cable entry to conduit.
sunny rhyl, thanks very much assessment is a week tomorrow though, are you working on RAF valley?there will only be one 2.5 in the one to the socket below the cu then 1mm to light and out of light to switch so only a max of two 1mm's from where the T will be, its better practiceto use singles i thought but im a tight arse..
No, we got a couple of days in a caravan park somewhere near you actually, and Im going across to watch the bikes at Anglesea for a day.
I used to work for a firm based in Rhyl, 'total trade services' if you know them. ;)
was about 8 years ago now IIRC, I only worked for them for about 3or4 weeks,
was on pricework and they had promised me the earth, I was in reality only getting enough jobs to cover
was about 8 years ago now IIRC, I only worked for them for about 3or4 weeks,was on pricework and they had promised me the earth, I was in reality only getting enough jobs to cover
