Hi guys. I'm trying to figure out how to fit 8 325w solar panels in series on a outbuilding(2002 build)at my home. It's steel framed with timber joists and a corrugated concrete roof. I would like to do all the work myself and get a sparky to check and connect it to the grid. I'm only going for 8 as it wont be a MCS certified install and want to limit the amount I send to the grid as I wont get money for it. Would be nice to get it MCS certified later, is that possible?
The outbuilding is 35m away from my meter and it has a CU in it but I think the voltage drop would be too much to install an inverter within the building so im planning on running 4mm 2-core swa(too small?) in the ground to send the DC to an inverter in my garage which is next to the meter.
I was thinking of fitting the solar panels to the roof with 10mm SS hanger bolts(would galvanized be o.k?) at the top and the bottom of the solar panels with just 6mm flat alu bar to the pre-drilled holes, should I spend the extra and use proper rails? I'm trying to do it as cheap as possible and not fussed if it takes longer/is a bit of a pain to do.
I would want to use a 3.6kw inverter so I have a chance to add panels in the future and stay below the 3.68kw allowance.
Will I have any problems doing it this way? Do I have any other option that wont cost more? Are BC going to come around and give me a big fine? Cheers
edit- Forgot to say i currently have a very small off grid system on the building that isn't being used to it full potential. Would I have to remove this?
