FunkyCatUK
- Joined
- May 28, 2021
- Messages
- 22
- Reaction score
- 0
Dear all,
Just wondered if anyone could solve this puzzle:
Today I changed the headlight bulb on my car. It all worked fine when fitted, but then -
Not sure if any members would have any idea what the problem was.
Thank in advance
- When I took the ignition key out I noticed the headlights stayed on (I've had the car 10 years - they only work with the ignition key in).
- I then tried to start the car and there was absolutely no cranking from the battery at all.
- Checked the voltage and it showed 12.6v or thereabouts.
- Tried to start again and no joy.
- Noticed that the voltage dropped to 8.5 on turning the ignition key on, but absolutely no sign of the car trying to start at all.
- Tried to turn on the headlights and the main beam (the bulb I changed on one side) were dead on BOTH sides of the car!
- Key fob operated locking also seem dead (but battery shows back to 12v).
- Checked if I broke, disconnected any wires on the headlight cluster but they seem to be ok.
- Lighting and ignition fuses are both ok.
Thank in advance
