Basic bathroom question...
hmm time to upgrade my avatar then...Thought as a MEM RCBO it might work, will keep looking.
new enlightened diagram ...
What kind of terrier is that?
Your fan isolator is ok if you don't want an over-run. If you do you will need a perm live and a switched live to the fan.
What kind of terrier is that?Your fan isolator is ok if you don't want an over-run. If you do you will need a perm live and a switched live to the fan.
No overun needed or wanted... got a window!
100% mutt! - 3 months old - Patterdale, lab, boxer and ?, Called "Magic" ; \
No overun needed or wanted... got a window!100% mutt! - 3 months old - Patterdale, lab, boxer and ?, Called "Magic" ; \
Then you don't need a 3 pole isolator a 2 pole will do! (allows you to isolate Sw Live, Perm Live and Neutral with the 3 pole)
I have a Patterdale :D Lovely little beastie :)
it appears i owe someone a apology Blushing
it was your mbc/rcd combined unit you linked to.
So I aquired an Eaton MEM 6A RCBO (not cheap!) from a local Newey+Eyre which fitted perfectly into the CU, wired up all the JBs, isolator, fan and lights. Just need to finish wiring the switches and give it a test. Getting it checked on Fri. BCO at the same time probably.
Thanks for the help! :)
Paul
So I aquired an Eaton MEM 6A RCBO (not cheap!) from a local Newey+Eyre which fitted perfectly into the CU, wired up all the JBs, isolator, fan and lights. Just need to finish wiring the switches and give it a test. Getting it checked on Fri. BCO at the same time probably.Thanks for the help! :)
Paul
Looks lovely except for the T&E wrapped in blue insulating tape. What's that all about?
I'd be swapping that for a 'proper' joint.
:D
(did your puppy help?)
Looks lovely except for the T&E wrapped in blue insulating tape. What's that all about? I'd be swapping that for a 'proper' joint.
Thanks!
The nasty joints absolutley not mine - pictures fixed for avoidance of doubt! Actually they are part of the UFH which is to be decommisioned - though I did take a look under the nasty, goopy, sticky tape and they are decent looking crimps.
Puppy ran off with the plastic blanking plate from the CU, looked for it for bl**dy ages, before locating in his bed!
Thanks! The nasty joints absolutley not mine - pictures fixed for avoidance of doubt! Actually they are part of the UFH which is to be decommisioned - though I did take a look under the nasty, goopy, sticky tape and they are decent looking crimps.
If it's crimped it's not so bad - heatshrink so much more 'professional' :D
Good when the puppy 'helps'! At least he hadn't eaten it.........
:D
