- Feb 10, 2009
- 342
- 17
This has arisen because a customer has asked me to change white accessories to chrome versions this will include a couple of TV points.
I know very little about aerials as wil become apparent.
The first two pictures show a combined FM/TV faceplate behind this are two coax cables - presumably one is from the TV aerial the other from the FM aerial. Customer does not want/use FM so I intend to just use a TV point and not connect the FM coax.
The second two pictures show a TV faceplate. Now behind this again there are two coax cables. I'm wondering is this just being used to join the incoming coax to the faceplate to provide TV in that room and then the second coax is a link to the other room where the combined FM/TV faceplate mentioned above is. I guess what I'm asking is is the single TV point which accepts two coax cables simply a junction? If so can I use a standard TV faceplate to join the two coax cables somehow?
Many thanks!
Many thanks!
