Bathroom Extractor Fan, Shaver Outlet And Underfloor Heating Mat. (A Bit Of Guidance)
jas0n
Sep 27, 2012
26
Sevenoaks
Hi everyone.
I just needed a bit of advice if I was doing the right thing.
Bathroom extractor fan - I have run of the lighting in the bathroom with an isolation switch outside the bathroom. I heard something about if there is a window in the bathroom there was no need for an Isolation switch, but I thought I should still have it for safety.
Shaver outlet - Am I right in thinking it will also run of the lighting as it is low voltage with transformer.
under-floor heating mat - run from the ring to a fused spur and then to the thermostat.
Jason
Isolation  switch and windows have no connection with each other whatsoever  Jas0n .
All bathroom electrics through an Arceydee.
Yes , shaver fed from lighting , must be isolation tranny.
I think the guidance that you are confusing is the general rule that where there is an opening window then the need for a run on timer can be omitted. Rooms without windows should maintain the fan for 15 minutes after use. Most manufactures state that fans should have a reasonably positioned local isolator. But a lot of your questions can be answered by reading the manufactures instructions for the accessories you are installing.
Doc H. .
