Ronvyoung
Hi All
I have a fair understanding of electrics but need some help with a bathroom circuit. The bathroom light is taking longer to come on(typically 18 seconds) and I am not sure what to replace. I have checked the bulbs which are ok.
Basically the light unit is a flush ceiling fitting with two 2pin d type bulbs and a unit between the two with a wire to each bulb socket. An extractor fan is linked in with the light with an isolation switch outside the bathroom. Next to this switch is a box which houses a PCB with a transformer and other components. I assume this is a low voltage unit but not sure whether it is for the light, the fan or both.
My question is whether the component in the light is a ballast and would this be causing the delay?
Ron
Ron
